Ac relay location?????
HI THERE i DO NOT FIND IT IN THE SPOT MENTIONED IN THE BENTLEY MANUAL
ANY iDEA ALSO i FOUND A RELAY ON THE SIDE OF THE FRONT FUSE BOX ATTACH AT THE GROUNDING POINT I THINK? WHAT IS THAT ONE,ANYTHING SIMILAR IN YOUR CARS? THANKS AB |
What year is your car?
It's hard to answer without knowing what year car you have. On my 86 there are 2 AC relays, the round one on the fuse panel and one in the front of the smugglers box.
it is a 1978 911 sc
Smuggler box and fuse panel. Is this a factory ac unit or an aftermarket?
I think it is a factory but converted
where is the smuggler box ? thanks AB |
Front trunk under the carpet there is a lid with a simple latch that you twist so that you can open the lid.
The main AC power relay is inside the smuggler's box (feeds the fan switch on the dash). The relay on the fuse panel in the luggage compartment (I suspect it is the one closest to the front of the car) controls the fan on the front AC condenser.
where does the compressor get the current from?
AB |
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_82SC_AC.jpg |
