Door hinges base plate question.
After a complete re-spray I'm having trouble adjusting the doors with the new rubbers. Can somebody tell me how many hinge base plates are needed per hinge? Is this different on every car?
Champaign and Burgundy 3.2 (1986)
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 06-11-2009, 01:21 PM
My limited experience, with three different year cars, was there was one shim under each hinge. However, I would suspect that you will find a variety of answers. On one car I fabbed a second shim to align the door gaps but aligning the door is also done with a single jack and a block of wood, if you read the Porsche books. Bottom line, I'd say there is no fixed rule but I'd defer to any body/paint experts.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 06-11-2009, 02:00 PM
Tx for the reply.
Any more body/paint experts out there?
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 06-12-2009, 04:28 AM
Slumlord
Porsche_monkey's Avatar
It is a shim. You have to use them to fit the door to the car. Start with one and go from there.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-12-2009, 05:12 AM
68Sporto
MrJTP's Avatar
According to the shop manual, you use as many as it takes to align the door.
Within reason of course.
Tony
Porsche owner since 1967
1998 Boxster
1968 911 Sportomatic project
Old 06-12-2009, 07:07 AM
+1
And you may need shims for the latch as well. They are frequently available on ebay.
Steve B.
1972 911t
1999 328is
Old 06-12-2009, 07:47 PM
Slumlord
And the 'special' triple square tool to get the latch bolts out.
84 Cab - sold!
Old 06-13-2009, 05:07 AM
Shims are easily made if you need one. Remove one from your hinge and you'll see they are made of thin aluminum. You can by thin sheets of aluminum stock at a hardware store and simply use your old shim as a template.
L.J.
Old 06-13-2009, 09:32 AM
