HarryD's Avatar
Reviving Dead NiCad Batteries
I have a 9.6 volt battery drill I use for all kinds of stuff around home and lately, the battery pack has not held it's charge and even when charged was pretty wimpy. After charging it, I checked the voltage and it showed ony 5 volts.
I decided to look for a replacement battery and found out it would cost $40 to get a new pack. Since that is almost the cost of a decent new one, I decided to see if I could revive the old one.
A Google search turned up this web page: http://ysuusy.com/easybatteryfix.html.
I followed the procedure and now my battery is like new.
One issue was that after several passes on the full pack, it only came up to 7.6 volts. I then noticed that in addition to the two terminals that my drill used, there were two more points. I checked them with my voltmeter and found out that one was a second negative but the other was the 4.8 volt contact. One side was ok and the other showed 1 volt! I zapped just that side and now both sides showed 4.8 volts.
If you have a dead NiCad, you might want to try this before giving up.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-05-2009, 07:41 PM
Brother's Avatar
Cool. I would really like to know how consistently this works.
I'll be really interested in how your drill pack stands up over time. Keep us updated.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 05-05-2009, 07:53 PM
slodave's Avatar
It works. It won't keep NiCd alive forever, they will start to degrade, but you can extend their life for a few more years.
Old 05-05-2009, 08:05 PM
Zeke's Avatar
This was here before, There is a YouTube video of a guy "surging" his drill motor battery with welder leads!
Old 05-06-2009, 06:21 AM
