77' 911S warm start issues
Guys I need some help, I am just about at my wits end w/ this car. I love it but every time I take it out this is happening at an increasing rate. I have had to be towed home several times and that is just plain embarrassing. The car starts fine when cold but I have it out for a while when I shut it down and I try to start it again I get nothing, the gauges all "bump" but it motor will not turn over at all, nothing. I can hear the fuel pump running but the motor will not crank. I have charged the battery, but the motor does not turn over sluggishly like w/ a weak battery, it does nothing, no click, nothing. I have cleaned all the contact posts on the battery, made sure all cables are tight, I have cleaned the contacts on the solenoid and the starter but still it persists. The car will run great. I will shut it down, immediately turn it over just to make sure it will start again, walk away for 10 minutes, sometimes less, and when I come back I get nothing, it's like the battery is dead but I know it is not. I am at a total loss for what is going on, getting to the point I may have to trade her in on a Beemer and get out of the Porsche game as this is so frustrating, being Porsche-less is the last thing I want but I can't afford to keep paying $100 tow bills when I can't find helpful strangers to help me "bump start" her!!! ARRGGHHHH!! Any help would be greatly appreciated!!!!
C
Many posts on this subject.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL Last edited by Walter_Middie; 05-22-2009 at 06:55 AM.. |
I used to get this problem, but not often. An old starter gets relly hot and the resistance gets so high that it performs like a dead battery if it cranks at all. I could always push mine and drop it into gear to start it, but that sucks. Sometimes it wouldn't crank at all, but I would wait 20 minutes and then it would be good.
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
Update to original thread!!
Ok guys, the same problem has happened for 3 straight days now but once I got her back home (after another bump start) I let her sit for almost 3 hours, the kids and I had dinner and watched a movie, but still nothing from the starter. I hooked her up to a battery charger and after 5 minutes she fired right up???? Bad battery??? I have one of those "smart chargers" and it claims the alternator is fine but I am asking for any other advice from the peanut gallery!!!
thanks in advance, C
Several auto parts stores offer free checking of your battery.
To troubleshoot your electrical connections here is a quick and easy procedure: http://www.pelicanparts.com/techarticles/mult_starter_diag/mult_starter_diag.htm
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
also check the ground strap and clean.
if still no go, you can do the solenoid "rebuild" as walter said or get a new starter. you might see if you can find a new solenoid. but check and clean all connections, even grounds. i have never checked or heard of the contact from the starter to the engine being a problem, but you never know, if corrsion or grease/dirt got bad enough, i suppose it could be an issue. anyone hear of ignition switch itself being the cause?
I have also had a bad starter solenoid. No warning, just one day after a hot run, the starter did nothing. Then the next day it worked like new. But I didn't like the idea of getting stranded, so I put in a new starter. No more problems.
