Bench Bleeding Carrera Tensioners
I'm preparing to do the recommended upgrade to my 76 911s with a 78 3.0L engine. I've got Wayne's book, read all the articles on the forum related to the subject and as a final re-read before diving in, I noticed an addendum to the on-line tech article. The addendum states the tensioners need to be bled by submersing in oil, pulling the keeper pin and pumping the actuator until all the air is expelled. This sounds reasonable, however having not done this I am concerned replacing the pin in order to install the tensioner may be a problem. Does anyone have experience in this Porsche recommended bench bleeding procedure that may be of assistance?
Fred
76 911s WB 3.0L
72 Int. Scout II
06 Mustang GT
"Limping in the right direction is always faster than running the wrong way"
Old 05-18-2009, 08:04 PM
Capitalist and Patriot
911Freak's Avatar
What I did was:
using a small 2qt bucket
fill said bucket with 1qt oil
completely submerge tensioner in oil
Then-
pull tensioner pin
pump tensioner by hand a few times until all air bubbles stopped coming from tensioner
and finally, compressed tensioner one final time with one hand while inserting pin with the other hand
presto... ready to go!
repeat with the other tensioner and your set!
Hope this helps
I'm sure others will chime in with much more eloquent directions and descriptions, but thats how I did mine~
Good Luck
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 05-18-2009, 08:37 PM
Great, that answers the question regarding the reinsertion of the pin. I may try to hook up the feed tubes and draw from a reservoir of oil rather than submerging, but either way I was concerned about the pin. That issue is solved...thanks for the quick reply.
Fred
76 911s WB 3.0L
72 Int. Scout II
06 Mustang GT
Old 05-18-2009, 09:50 PM
The one quart oil cans were the ideal size for this procedure. However, I think they're collector items now.
Sherwood
Old 05-19-2009, 12:38 AM
i use a pump style oil can with a short hose attached to a banjo from an old tensioner metal line. use the normal banjo bolt and pump until it firms up. as far as squeezing by hand to reinstall the pin, that would be difficult....use a vise and go slow.
206 637 4071
Old 05-19-2009, 08:03 AM
I did something similar and used a large channel-locks to compress during the bleeding and to reinstall the pin.
Jerry M
'78 SC
Old 05-19-2009, 08:14 AM
