charlesbahn's Avatar
Wheel Bearing Mahem- What would you do?
Finally got around to investigating the grinding noise from my left rear wheel- 1st thought was wheel bearing, second was CV joint- so here it is-
So obviously it's the wheel bearing. So, if it ain't broke, should I also redo the right side?
Old 05-23-2009, 04:34 PM
DUK DUK is offline
DUK's Avatar
I would say yes go ahead and change the other side. But if money is tight and you don't feel too much play or hear anything with the other side, leave it for now.
Looks to me like the bearing took a shock at some time. Did you hit a curb or something with this side?
BTW- what year is the car?
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 05-23-2009, 04:46 PM
Navin Johnson
TimT's Avatar
YES...The right side could let go the day after you finish the left side... or it could go for another 50K miles...
Is that a chance you want to take?
'69 911 GT-5
'75 914 GT-3
and others
Old 05-23-2009, 04:48 PM
No, didn't hit hit anything was just clicking along thinking how great life was with such a nice car - then a "bang" and a rubbing noise that got louder and louder, and then a little shudder from the left rear. Then I shut her down and called AAA.
The car is a 1985 slant nose conversion with "turbo look" origin. Actually now also has a proto turbo.
Naw, it's the only time I've had to be flatbedded home. Guess I'll do both. Uh-oh! now that I'm there, should I also do the front. i think I already know the answer!
Charles
P.S. Sorry for the crappy 2nd photo, at least the neighbor's yard was in focus.
Old 05-23-2009, 05:34 PM
initial's Avatar
I did the right rear when I first purchased my 89 2.5 years ago. I didn't do the left, but did store the bearing in the freezer to have it ready... The left has not yet showed any signs of weakness...
95 Carrera 4 Black/Black Coupe, Row M030, Bilstein HD
Past - 89 911 3.2 silver cab
Old 05-24-2009, 05:36 AM
juicersr's Avatar
The bearings are cheap. Unless u know that the other bearing was done recently, FIX IT TOO. I just replaced a noisy rt bearing and went ahead and did the left and saw that the grease was drying and it was gonna go soon too, so glad i did. Great to know u have one less thing to worry about. Plus, if u do it yourself, once u do one bearing, u have fresh in ur mind how to do the other side and it usually goes faster.
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 05-24-2009, 05:46 AM
juicersr's Avatar
PS, if u do the fronts (which are easier) do yourself a favor and take ur hubs to a shop to have the races pressed out and new ones pressed in, or u'll end up beating the hubs to hell.
dzugautomobili.com
Old 05-24-2009, 05:50 AM
Green 912's Avatar
I bet the cage failed and the rollers bunched up. change them both if they are the same age. car jacked up, tools out and learning curve is 3/4 the job. You can remove the bering race that is on the hub by slitting it 4/5s the way through with a dremmel and cut off wheel then pop it open with a hammer hit on a sharp chisel.
Old 05-24-2009, 06:38 AM
Changing the turbo bearings is not a small job, unlike on the NA cars. Go in with the right attitude, go slow, and take the arms completely off and bring them to a very competent machinist. The aluminum arms are insanely expensive if you or the shop booger them up.
Ken
1986 930 2016 R1200RS
Old 05-24-2009, 10:59 AM
