-   -   Does new alternator VR need break-in? (http://forums.pelicanparts.com/porsche-911-technical-forum/474158-does-new-alternator-vr-need-break.html)
alniki 05-12-2009 06:55 PM
Installed a brand new Valeo voltage regulator (from our host) to the alternator and now the charging light stays on with very slight blinking at idle and only goes out at 2000+ rpm.
Since the brushes of the new VR only contact the rotor copper wire at a smaller area than the crescent perimeter of a used one, could that new VR brushes need some time to break in before the charging light would go out at idle? Thanks a lot!
mca 05-12-2009 07:03 PM
Check fan belt ... Might be loose
alniki 05-12-2009 07:09 PM
Pretty tight!
Rot 911 05-12-2009 07:12 PM
Originally Posted by alniki (Post 4660239)
Pretty tight!
It does not need to be "broken in." Oh and you should have at least 1/2" deflection in the middle of the belt. Too tight is not good at all. Leads to premature bearing wear.
alniki 05-12-2009 07:24 PM
Kurt, I don't like it to be too tight, either. :)
Am thinking about the possibility of slipping at the pulley area as I used some silicon spray to finish the alternator fan/case after cleaning them. Though I did slightly clean the central part of the fan there may still be some left.
