dme relay replacement
I replaced the dme relay on my '87 yesterday. The old one comes out easy but I could not replace it without unbolting the seat. Is there some trick to holding the plug (which moves away) so you can plug the new dme relay in? There isn't much room under those power seats. Unbolting the seat by the side of the road would be a real pain. Thanks.
1987 Indian Red Carrera Targa |
The plug is not fastened down to anything; it just happens to be a little stiff due to the wiring and plastic/rubber enveloppe. Move your seat as far forward as it will go, reach in from behind the seat and pull the plug off the relay. Now push the seat back and raise the power seat as high as it will go (if you have power seats) and then remove the nut that holds down the relay. Remove relay, install new one; push seat forward and, again from behind, push the plug onto the relay. Does this make sense? Hope it helps.
Henri '87 Carrera coupe: Venetian blue |
good idea-thanks.
muck-raker
IIRC, Mr. Bentley says one should remove the seat to access/replace the DME relay. I've never done this. I just move the seat BACK as far as it will go. This always allows me just enough access to replace it.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Wash. State
"...seat BACK as far as it will go. This always allows me just enough access to replace it." Me, too! NO problem.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
