Blade
What years steering wheel fits an 1989
Ok, I have a 1989 3.2 carrera (not a 964) and I purchase a raised hub steering wheel from another Pelican poster. But the Steering shaft spline on that wheel is ~17mm and the steering Shaft on my 1989 measures about 20mm's. What year steering wheels will fit my Carrera and since I need to sell this other wheel, what years does it fit. The wheel looks like the stock 4 spoke Carrera wheel but the hub spline is smaller then mine. Any help would be appreciated. Any one need a raised hub black Carrera wheel with a ~17mm spline?
Thanks,
Blade
Blade
89 3.2 Targa
Old 05-11-2009, 10:10 PM
3.4 Bigger is better
88-diamondblue's Avatar
The wheel that you purchased is most likely for a 944. The steering wheels were the same but the hub is a different size than the 911.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 05-11-2009, 11:05 PM
Recreational User
porschenut's Avatar
What's the part number stamped on the wheel?
Old 05-12-2009, 06:43 AM
Mitch Leland's Avatar
I make a steering column bushing that fits all 911 steering hubs and columns from 1974-1989. So I would assume that any steering wheel in those years would fit the steering shaft spline. Whether the base of the steering wheel will match the column hub is another question I can't answer.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 05-12-2009, 07:35 PM
Banned
I bought just the raised hub section once thinking I would use my stock 89 911 wheel but it, like yours, wouldn't fit. I sold it to someone that new what it was and boutht a Porsche 930s wheel brand new. I really like it.
Old 05-12-2009, 08:08 PM
Blade
I think michael is correct, the number on the raised hub steering wheel is 994 347 084 09 (10VERL). So it looks like I have a 994 wheel. Thanks for the help
Blade
89 3.2 Targa
Old 05-15-2009, 11:29 AM
