Band.
What is this THICK 12x24x5 washer for?
I ordered a few of these for my new motor mount excursion, and didn't find a use for them. My two (more knowledgable) helpers had never seen them either.
WHAT or, rather, WHEN, do you use these in a "motor mount" or trans mount application? I do know that I sure didn't take any OFF of the car when I took the motor out. TIA! ![]() ![]() edit: SORRY, IT'S 12X34X5 thick.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Wer bremst verliert
Insert a lockwasher on the engine bolt, then one of those, then pass the bolt through the mount.
I dont recall seeing them on standard mounts but WEVO mounts use them.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Those things hold everything together... get it wrong and the engine will fall right out of the car.
Bonehead Ask me how I know.... -Troy
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler, Steve Wong Performance Chip 2001 Boxster 2.7L (Orient Red), bone stock |
Band.
Thanks, Troy
.Actually, these are NOT the saucer-shaped cuppy washers that go on each side of the motor mount, and on the bottom of the trans mount. These are SOMETHING ELSE, and that's what I'm trying to figure out. These are flat, really thick and about half the O.D. of the cuppy, saucery washers that you so abruptly learned about.
G-50 ... I think.
AutoBahned
what is the p/n??
it may be a different prefix if only for G-50 cars can also check on PET |
Band.
Oops sorry. 999-025-074-01-M100
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=999-025-074-01-M100&catalog_description=Washer%20%28%31%32%2E%34%20x%2 0%33%34%20x%20%35%20mm%29%20for%20Engine%2FTransmi ssion%20Mount%2C%20Each%20
Don't know if this helps, but looks like it's for "RS Motor Mounts" on 964 and 993 cars??
![]() Click link and scroll down... http://www.pelicanparts.com/catalog/shopcart/911L/POR_911L_UP911L_pg2.htm
- Everything's easier once you get started. - '95 993 C2 '73 911 Targa '88 BMW M3 '84 Mercedes 190e 2.3 16v |
