Has This Ever Happened to Anyone Else
Hi All,
It was a nice evening for a drive and then this happened. Has this ever happened to anyone else? Does anyone know the fix? I took the mirror off the car and it looks like the mirror should fasten onto threads on top of the spring but I can't compress the spring enough to get the thread started. Am I missing something???
Help!!!
Old 05-15-2009, 09:04 PM
If it just happened you should be able to get an annulment after you sober up...I don't know about the mirror.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 05-15-2009, 09:11 PM
Won Won is offline
Won's Avatar
Exact same thing happened to mine. Most of the thread in the mirror housing was stripped. The spring tension made it very difficult to push the bolt in far enough to catch the remaining good thread, as you found out. I ended up cutting a couple turns off the spring and put JB weld on the tip of the bolt. Unfortunately that reduced the spring tension too much so now the housing vibrates.
First check to see if the threads are ok, then get a helper to compress the spring while you try to turn the bolt. If you decide to cut the spring, may try half a turn at a time. Good luck!
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 05-15-2009, 09:18 PM
I'll give it a try. Thanks Won.
82 911SC Targa
Old 05-15-2009, 09:29 PM
The wife loved the reply
82 911SC Targa
Old 05-15-2009, 09:40 PM
porsche8777's Avatar
Loose Mirror Tech Article
83 SC CAB
98 M3
87 944S
Old 05-16-2009, 07:51 AM
Thumbs up
Great Thread. Thanks Porsche8777
82 911SC Targa
Old 05-16-2009, 08:27 AM
Originally Posted by porsche8777 View Post
Thanks again for the thread Porsche8777. It worked like a charm. Having never done this before, once you get past the fear of breaking the glass, it's a pretty simple procedure. Took about 15 minutes to complete. The longest part of the repair was driving to the Kragens to get a Torx55 for the bolt.
82 911SC Targa
Old 05-16-2009, 09:32 AM
Designer King
Paulporsche's Avatar
I used an Allen wrench on mine since I didn't have a Torx. It tightened up fine.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-16-2009, 10:22 AM
