-   -   Has This Ever Happened to Anyone Else (http://forums.pelicanparts.com/porsche-911-technical-forum/474740-has-ever-happened-anyone-else.html)
cs911 05-15-2009 09:04 PM
Hi All,
It was a nice evening for a drive and then this happened. Has this ever happened to anyone else? Does anyone know the fix? I took the mirror off the car and it looks like the mirror should fasten onto threads on top of the spring but I can't compress the spring enough to get the thread started. Am I missing something???
Help!!!http://forums.pelicanparts.com/uploa...1242446491.jpg
snbush67 05-15-2009 09:11 PM
If it just happened you should be able to get an annulment after you sober up...I don't know about the mirror.;)
Won 05-15-2009 09:18 PM
Exact same thing happened to mine. Most of the thread in the mirror housing was stripped. The spring tension made it very difficult to push the bolt in far enough to catch the remaining good thread, as you found out. I ended up cutting a couple turns off the spring and put JB weld on the tip of the bolt. Unfortunately that reduced the spring tension too much so now the housing vibrates.
First check to see if the threads are ok, then get a helper to compress the spring while you try to turn the bolt. If you decide to cut the spring, may try half a turn at a time. Good luck!
cs911 05-15-2009 09:29 PM
I'll give it a try. Thanks Won.
cs911 05-15-2009 09:40 PM
The wife loved the reply :)
porsche8777 05-16-2009 07:51 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/468847-loose-mirror-tech-article.html?highlight=loose+mirror
cs911 05-16-2009 08:27 AM
Great Thread. Thanks Porsche8777
cs911 05-16-2009 09:32 AM
Thanks again for the thread Porsche8777. It worked like a charm. Having never done this before, once you get past the fear of breaking the glass, it's a pretty simple procedure. Took about 15 minutes to complete. The longest part of the repair was driving to the Kragens to get a Torx55 for the bolt.
Paulporsche 05-16-2009 10:22 AM
I used an Allen wrench on mine since I didn't have a Torx. It tightened up fine.
