dsmyth's Avatar
85 power seat electrical issue
I just received my newly recovered seats and installed them today. On the drivers side i could only get the seat back to raise but not lower.The up and down work. When I reach under and move the large 4 prong plug over a notch I get the reverse, It lowers but does not raise forward. It was working and I must have messed up some connector underneath. My back is killing me from the install and it is hard to see underneath. Does any one have a suggestion or recognize my error before I pull that heavy seat out again? thanks Doug
Doug
97 C2S 993(last one)
95 993 cab- 85 911 M491
87 944 Turbo- 70 914-6
63 911
Old 05-15-2009, 09:32 PM
Perhaps the trim shop got the switch wiring wrong. Do a search here for the correct wiring/plug and pull the switches to confirm they are correct.
good luck,
Ben
1986 3.2 Carrera
Old 05-16-2009, 05:19 AM
muck-raker
kidrock's Avatar
I'm pretty sure the only way to make the necessary checks is to remove the seat again, sorry. Make sure the wires are in their proper spots. If so, you may need to clean some contacts...make sure to put a tiny dab of di-electric on any contacts before re-connecting.
good luck.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-16-2009, 01:31 PM
