faverymi's Avatar
Perma-tune options.
Hi to everybody.
My name is Felipe and I just bought my first porsche
1977 911s targa with 94.000 miles. stock one owner.
I've been doing a few things just by reading this forum.( so helpful)
I have a problem. Permatune box is not working (tested)
What would you recommend:
Repair existing permatune.
Find used one
Replace with a Bosch.
Go MSD
I appreciate every answer.
Thanks again
Old 06-11-2009, 09:13 AM
T77911S's Avatar
MSD
you will find the majority do not like permatune.
it is probably split bosch vs MSD. MSD is much cheaper, you can get one local if you need one. take a look in most race cars and you will find MSD.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-11-2009, 09:21 AM
Designer King
Paulporsche's Avatar
Agree w/ T77911S. Nothing wrong w/ Bosch. It's just that the MSD does the same thing @ a lower cost. You can run wider plug gaps w/ the MSD, but I haven't seen any data to show if there actually is an improvement over stock gaps w/ Bosch.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-11-2009, 02:18 PM
faverymi's Avatar
Thank you for your answer.
Question:
Would you even consider buying a used permatune(to save money for now, bigger fish to fry)
or should I buy the complete MSD set up? (box, coil, tach adapter, wires)
Thanks for the input.
Old 06-11-2009, 03:44 PM
i wouldn't consider a used permatune. Though if you dig into it there are reports of some of the types/colors being more reliable than others. MSD is relatively cheap, and tried/true. It's one of those things I don't want to think about, just have it work.
Babak
Old 06-11-2009, 04:00 PM
Warren Hall Student
Bobboloo's Avatar
A good used Bosch is a good alternative if you want to save some money.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 06-11-2009, 04:22 PM
RETIRED
Joe Bob's Avatar
They don't call them Permacrap for nothing.....
2012 ML350 3.0 Turbo Diesel
Old 06-11-2009, 04:53 PM
Designer King
Apparently the older Permatunes were better than the newer ones. You will have to search, but you can tell by their color; blue or silver. I think I'd rather go w/ a used Bosch than a used Permatune, although how long does any part that is 30 yrs old have left? For the MSD to work I think you need all the parts you mentioned.
Better check w/ them re the coil. I'm not sure if you can mount the Blaster 2 coil upside down.
Paul
Old 06-11-2009, 07:57 PM
RETIRED
Joe Bob's Avatar
Permatunes are not repairable...they "pot" them...i.e. dip the whole enchilada in tar.
When they break, you gather twenty up and create an anchor....a crappy anchor.
Old 06-11-2009, 08:07 PM
HarryD's Avatar
If you want to mess with the wiring, MSD is the way to go. To use the factory coil location, you want to get their "High Vibration" coil.
If you go with a Bosch Box, it is plug and play. Also, unlike Permatune, a Bosch box can be repaired.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-11-2009, 08:50 PM
