Removal of rear side window SC
Hi,
I'm stuck in the progress of removing the rear side window on my SC even before starting. How is it done? I don't find any information in the service manuals or in the forum. Help and tips how to get it back in again is also appreciated. Thanks in advance! |
Search "rear glass install" many threads on this. I just replaced my head liner and had to remove all the glass. Not for the weak kneed I'll tell you. Start by purchasing a plastic putty knife about 2.5 inches wide. Carefully pry off the trim a little at a time DO NOT BEND THE TRIM. Work slowly and methodically. After the trim is off have someone push on the glass with their stocking feet and the glass will come out. Work form the back to the front. Installation, put rubber on glass, put in trim( I installed trim by squeezing with my palm and fingers using my palm to push the trim in place) Next put a cord around the lip on the inside of the seal have someone push on the glass and pull the cord as the glass pops in place. It may take some practice but you'll get it.
This is easy. I have to put mine back in today.
There are 2 allen head bolts (socket head cap screws) behind the B pillar and one or 2 at the back of the window. They just pop out. |
Thanks kodioneill!
This was exactly what I was looking for. |
| All times are GMT -8. The time now is 07:18 AM. |
