rws rws is offline
electrical gremlin
the directional signal lights on my dash glow at all times i've been tracing a ground problem but can't find one . there was corrosion on one of my front units but after clearing that i still have the problem is this a common sign for some other problem or am i on the right track? my car is a 75 911s thank you
Old 06-18-2009, 08:51 AM
crustychief's Avatar
Not sure about a 75 but the flasher could be going bad.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 06-18-2009, 10:28 AM
pozee's Avatar
Seems you are on the right track.
Check all sockets and make sure the bulbs are the correct ones. I once used a two filament bulb in a single filament application and had some crazy things happened). The sockets should be clean and free of any corrosion. If any of the bulbs are loose in the sockets, fix that by using a wedge (plastic or wood).
pozee
Old 06-19-2009, 04:24 AM
had the same issue and had to change the flasher
clean flasher connector pins first before buying if this is what you decide
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-19-2009, 09:34 AM
