-   -   help with PPI leak-down numbers (http://forums.pelicanparts.com/porsche-911-technical-forum/475236-help-ppi-leak-down-numbers.html)
bkreigsr 05-19-2009 05:25 AM
I have been looking for a 911 for/with my son and we found a 81 SC with the following leak-down numbers from the PO PPI in 2004:
#1 - 20%: #2 - 8%: #3 - 9%: #4 - 9%: #5 - 10%: #6 - 9%
These numbers, especially #1, are out of my comfort zone and I'm trying to get an affirmation from the consensus of Pelican experts.
Should I run and hide, or is there the possibility that the car can still provide 5-10,000 more miles before a rebuild? It's going to be driven approx 2-3,000 miles/yr with 2-3 DEs/yr and an occasional autox.
thanks
Bill K
jsmithcds 05-19-2009 05:42 AM
info
how much for the car?
how many miles?
any mods?
A ppi 5 years ago with 20% in a cylinder would scare me........
imcarthur 05-19-2009 05:43 AM
2004? From the PO?
Time for a new test from an independent source.
Ian
tonythetarga 05-19-2009 05:57 AM
Five years is too long for those numbers to have any validity. That #1 is not a good number but it could also be an incorrect reading. Either way, you have some good shops in NJ and you might want to get a RX for a shop near you (or the car). Do your own PPI and get your own results.
jsmithcds 05-19-2009 06:04 AM
for $15k with 134,000 miles it must be immaculate besides the motor if you are considering it?
bkreigsr 05-19-2009 06:09 AM
if you must know, the only cars we have been considering are immaculate ones.
Physedfailure 05-19-2009 06:25 AM
Originally Posted by tonythetarga (Post 4671856)
five years is too long for those numbers to have any validity. That #1 is not a good number but it could also be an incorrect reading. Either way, you have some good shops in nj and you might want to get a rx for a shop near you (or the car). Do your own ppi and get your own results.
+1
PCA7GGR 05-19-2009 07:25 AM
Let us know what the "current" leakdown numbers turn out to be.
You might also check into how much a topend job goes for now days.
Steve@Rennsport 05-19-2009 07:42 AM
thanks
Bill K
Bill,
Any leakdown tests that don't tell you WHERE the observed leakage comes from is pretty well useless as thats the single biggest value of such diagnostics. :) :)
In your example, that 20% leakdown may simply be carbon under the valve which would be nothing to fear vs a ring or piston problem that would be expensive to repair.
I'd kindly suggest that any shop performing a PPI on a potential candidate who takes the time to do that mandatory leakdown, tells you where any air was escaping from. This allows you to make a much more accurate assessment of engine condition and potential repair costs, both of which are bargaining points.
bkreigsr 05-19-2009 08:16 AM
agreed
thanks Steve, thanks Tony for taking the time to respond.
Bill K
bkreigsr 05-21-2009 01:12 PM
Better news today.
Tony, you were right, we had another shop do a leak-down and here's what they found: #1- 3%, #2 - 2%, #3 - 1%, #4 - 2%, #5 - 5%, #6 - 3%.
We will post pics of the car when the deal is done.
It's a beauty and real nice starting place for my son to get an the air-cooled experience.
thanks for your advice and responses.
Bill K
