Gordo2's Avatar
Steering Rack Rebuild - Loose Pinion Roller Bearings
I'm in the middle of rebuilding my steering rack and as I pulled out the pinion, some of the roller bearings came out with it. Of course once one comes out, they all come out:
Is this normal, are the roller bearings normally held in place with grease, or should the casing hold them in place?
If it needs replaced, any idea on sources?
Thanks, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 04-04-2009, 02:53 PM
Gordo2's Avatar
Whatever
I wanted to get something done, so I regreased and put them back in. Seemed to work fine. I did look up on the internet - appears some are just made that way (loose in the retainer, held in place by grease).
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 04-04-2009, 06:43 PM
Zeke's Avatar
Good call. There is not a lot of info on steering racks. There are 2-3 rebuild thread here in the archives, but not easy to find. If the Wiki ever gets done, that will change.
Old 04-04-2009, 07:15 PM
Porsche 911 SC, SAAB SPG
I ended up replacing the needle bearing with a new ball bearing. There is absolutely no slop now. I also swaped out the rusted needle bearing further up the chain. It is covered by the rubber boot. I used two bearings for this one.
Here is the link that I used.
http://cgi.ebay.com/10-Bearing-6703Z-17x23x4-Shielded-VXB-Ball-Bearings_W0QQitemZ140267377438QQcmdZViewItemQQptZL H_DefaultDomain_0?hash=item140267377438&_trksid=p3286.m20.l1116
Basically it is a 6703Z double sealed bearing.
In fact I have some extra since I only needed three but I had to buy ten. PM me and we can work something out if you want.
Jeff C
Old 04-04-2009, 07:58 PM
grateful user
don gilbert's Avatar
rack
gordo, yes that is the way the bearings are, and be sure to dress up the tensioner slide and back of the gear where it ride, makes all the diff.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 04-05-2009, 06:33 AM
MAGA
Tim Hancock's Avatar
Here is my old post which has some bearing part numbers.
SC Steering Rack DIY Bearing Replace
I try start all my "how to" type posts with "DIY" so that when searching, I can type DIY in the search engine to help find my old posts.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 04-05-2009, 07:04 AM
How did you pressure test your rack?
Old 05-21-2009, 10:21 PM
