-   -   replacing clutch slave bleeder valve (http://forums.pelicanparts.com/porsche-911-technical-forum/475857-replacing-clutch-slave-bleeder-valve.html)
Decolliber 05-22-2009 09:10 AM
Part # 928-351-945-03. Mine is starting to get rounded off. Three questions:
1. when replacing it, do you need to bleed just the clutch or the entire braking systems as well?
2. if I am using a Motive power bleeder, does it matter if the clutch pedal is in or out when I bleed?
3. can the clutch bleeder screw be replaced by one of the speed bleeders for brake calipers that Pelican sells, or is the screw pitch different? The clutch bleeder screw takes a 7mm wrench and the brake bleeders an 8mm wrench, so I would imagine they might be incompatible.
88911coupe 05-22-2009 09:46 AM
1. Just the clutch
2. I assume in needs to be in the "up" or non depressed position, at least that's the way I did it on my '88 and it worked perfectly.
3. no idea
