Nine9six's Avatar
Stone guard removal and reinstallation
Can anyone post the process, tips, tricks for removing and replacing stone guards on a turbo?
Thanks in advance!
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 05-22-2009, 10:36 AM
emac's Avatar
I used a heat gun to remove and was able to reinstall with no issues.
Take your time and remember to be careful with how close you get to the surface.
Ernie 81 SC
Old 05-22-2009, 11:36 AM
Nine9six's Avatar
Ernie,
Did you wet the back of the new stone guards after peeling off the backing, prior to installation? I heard that makes them more managable (able to move/adjust) during installation process, but would think it might negatively affect how well they stuck to the surface.
Anyone?
96 993 C2 (Current)
Old 05-22-2009, 02:04 PM
Designer King
Paulporsche's Avatar
There are some threads on this. You will find them via a search.
The pros mix up a really weak soap/water solution which they spray on the surface, and sometimes on the piece too, which they then slide into place. Then, as the solution dries, they quickly smooth out any air bubbles and wrinkles w/ a squeegee or burnisher. Teh solution does not adversely affect the adhesive.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-22-2009, 05:27 PM
Super_Dave_D's Avatar
+1 very easy
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 05-22-2009, 07:41 PM
