Jim,
Greetings. If I remember correctly, i trimmed after gluing in those areas. If you scroll back up to post #1 and look closely at the pix, you can see exactly how much extra material I had while gluing. It appears to be an inch or so at the front and forward of the B pillars. Good luck with the project..........................Heat, stretch, clip, heat stretch, clip regards, Al |
Jim, don't trim until after it is all glued and set.
lookin good. if you put the headliner in a pillow case and throw it in the dryer for a while, the wrinkles go away.
http://forums.pelicanparts.com/porsche-911-technical-forum/626050-saving-73-crusher-17.html |
| All times are GMT -8. The time now is 12:19 PM. |
