Another FYI Alloy lug nut
While experimenting with various ways to take the anodize off my lug nuts I messed up on the first one.
I tried to use a 2" scotch brite wheel while it got the anodize off it also made the sharp corners kinda rounded off. So since this lug nut I won't be using I'd thought I cut it in half and see how much "meat" was holding the wheel and tires. Here you go http://forums.pelicanparts.com/uploa...1243123143.jpg |
Years ago easy-off oven cleaner used to take anodizing off really well.
| All times are GMT -8. The time now is 10:35 PM. |
