911Etarga's Avatar
Angry Running on 4 cylinders.
I have yet another problem with my '71 E.
I just fixed a leaking rocker shaft (you guys helped me out with that, big time!) After I set it down (it was jacked up on the passenger side for Cyl. #5 rocker) I started it up and went for a drive. The leak was fixed, but the power was really low.
Long story short, it is running on 4 cylinders. #2 and 3 are the culprits. I shot carb cleaner through the jets, jet holes, adjustment holes, etc(Zeniths). Checked for spark, they are getting spark. Changed plugs. Drove the snot out of it. Covered the intake stacks with my palm to suck fuel through.......no change.
What should I do next?
P.S. It has new wires, distributer, and everything else is re-built.
Random pic of my car....
'71 911E Targa
Old 05-12-2009, 01:45 PM
911mot's Avatar
The only thing I can think of is #2 & #3 plug wires swapped
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 05-12-2009, 02:02 PM
Zeke's Avatar
It is so easy to get the wires out of order. I think we've all done it at one time or another. Go back, take your time.
Old 05-12-2009, 02:31 PM
I would rather be driving
jpnovak's Avatar
I was thinking debris in the float bowls since #2 and 3 share the same carb segment. pull the carb top and have look. Also blow through the carb with 80-100 psi compressed air. Carb cleaner is often not enough to get rid of particulate matter.
Old 05-12-2009, 02:58 PM
911Etarga's Avatar
Thanks guys,
I made sure the plug wires were on the right plugs, but I haven't pulled the top of the carb yet, but I will tomorrow and post results. With the car tilted to one side, maybe debris moved around, and into the fuel passages......?
'71 911E Targa
Old 05-12-2009, 05:53 PM
I used to run across the same thing with my old long hoods. Remove the carb tops, mixture screws, jets, spray carb cleaner, and blow with compressed air. Then get your trusty unisyn, take some time and readjust.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 05-12-2009, 08:27 PM
T77911S's Avatar
i was thinking oil fouled plugs. try cleaning or new ones.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-14-2009, 04:52 AM
Peter T.'s Avatar
Shouldn't this topic be posted in the 912 Forum?
Sorry, couldn't resist!
Old 05-14-2009, 05:56 AM
911Etarga's Avatar
Ha-ha.....I think I would take a well running 912 over this thing right now, it's killing me!
So, I just tor apart, cleaned, and blew out the carbs..........no change, it's still running on 4 cylinders!!!!
Valve adjustment?
Scotch?
Grenade?
P.S. the plugs are good.
'71 911E Targa
Old 05-14-2009, 09:29 PM
T77911S's Avatar
plugs
RACE CAR:: sold
Old 05-15-2009, 04:59 AM
ruf-porsche's Avatar
Check your compression in theses cylinders.
Old 05-15-2009, 05:19 AM
911Etarga's Avatar
More info,
It was running well until the last 2 weeks, then it started back firing a little bit when I started it up, but still ran O.K. Then it just started running like crap, on 4 cylinders. The thing is, the problem cylinders are on the left side(2&3) and when I put a hose up to the intakes to listen, #1 sounds like it isn't sparking or firing as loud as the right side(4,5,6). The plugs are not fouled, and it seems to run smoothly, but way under powered. There was, and still is no smoke.
'71 911E Targa
Old 05-15-2009, 03:28 PM
I would tend to think you have something in the carbs, it may require taking them off and a rebuild, check fuel pressure, fuel filter, dwell, all of the basics. If it was running well before it should be something minor.
Old 05-16-2009, 06:30 AM
muck-raker
kidrock's Avatar
I don't like to beat a dead horse, but it sure sounds like a plug/plug wire/dizzy issue to me. 1) Check those plugs for cracked insulation or something.
2) Make sure you're getting spark at the ends of those wires.
3) If items #1 and #2 check out fine, check cap for cracks and/or wear. Take a good look at the rotor, too.
Always do the easy checks first. If these checks turn out OK, I'd move on to the carbs. Hell, an easy check for the carbs is to spray into them and around the bases while it's running. If there is a significant change in the way it's running, then you've found yer problem.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-16-2009, 01:22 PM
Any updates?
Old 05-24-2009, 01:48 PM
