I want to lower the ride height of my '79
Can anyone point me to directions on how to do it? It sits really high.
Old 06-20-2009, 08:48 PM
autobonrun's Avatar
Lots of posts on this subject.
Use the advanced search function and search in the title block for:
"Lowering"
"Spring plate"
"torsion bar"
"ride height"
One of these four will get you to a thread that has pictures and directions.
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 06-20-2009, 09:35 PM
the the is offline
like said above, do a search, but to get that down to a good ride height is a lot of work. The torsion bars need to be reindexed. Easy on the fronts, the rears can be a real pain on a 30 year old car.
The rear spring plates need to come off, and the bars reindexed, the ride height needs to be carefully set, and an alignment, at a minimum.
You are almost certainly going to want to replace the rear bushings while you have it apart, and a corner balance makes it handle and brake better.
Old 06-20-2009, 10:11 PM
the the is offline
If you are not mechanically inclined (or at least fairly serious about learning), and if you don't have a decent place to work on it, and a decent set of tools, jack, jackstands, etc. this will be a difficult job, esp. if you run into problems with things sticking or being difficult to remove (which is fairly common with the rear).
If you hand it in to a shop, it will be expensive.
Old 06-20-2009, 10:13 PM
Bill Douglas's Avatar
Yes. Either that or get a really fat girlfriend.
Bill '79SC
Old 06-20-2009, 10:15 PM
