80 911 SC, Orem, Ut
Stalls until engine is warm.
When I start my car and for the first 3-4 minutes it will stall if I let off the gas. Once warm it runs really well. There is a new Cold Start Valve in the glove box, would replacing the old one with this new one solve this. I am totally unfamiliar with the cold start valve.
Thanks,
Rob 1980 911 SC |
The cold start valve only engages when you turn the key to the start position, injecting fuel into the intake to initiate start-up. Your problem sounds more like a misadjusted Warm Up Regulator which enriches the mixture when the engine is cold, and leans it when the engine warms. Have you had your CIS system pressures checked? A too high cold control pressure would account for your situation. If you are getting an easy "first firing", then it's likely not the cold start valve.
Please post any additional information, such as back firing, popping, etc. You may also have vacuum leaks which are leaning the cold start mixture.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 05-23-2009 at 06:09 PM.. |
80 911 SC, Orem, Ut
It is a bit hard to start in the beginning but then will only keep running after it is warm. Do I need to go to a Porsche specific shop to have the CIS pressure tested?
No backfiring no popping etc.
Rob 1980 911 SC |
Keep asking questions here, you're in good community hands. Edit: I just read your other post about brake bleeders and realize the car is new to you. I would highly suggest that you find a good Porsche mechanic in your area--ask here, if necessary--and take your car to him and have your CIS given the once over to get it in full working order so you have a base line for performance. Make sure your ignition and valve adjustments are in order and get the CIS dialed in by an expert. Well worth the bit of expense, IMO.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 05-23-2009 at 06:34 PM.. |
80 911 SC, Orem, Ut
Ossiblue,
thanks for the info. I have a client who specializes in European cars. Porsche and BMW specific. I will take it to him on Tuesday and have things checked out.
Rob 1980 911 SC |
Designer King
Just to supplement what the others have said, make sure all ignition components are good. Have the mechanic check your fuel and warm and cold control pressures. He should also look for vacuum leaks. It is very common in these old cars that there are vacuum leaks in CIS components, the hoses, and around the intake runners and even the fuel injectors. The warmup regulator (WUR) is often out of spec or malfunctioning, resulting in a a too high control pressure and a too lean mix. He should set your CO to approx 3 to 3.5%, unless you have to pass an emissions test.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
CIS troubleshooting.......
You could check the fuel pressures (system, control, and residual) of you car without even running the engine. But you need a fuel injection pressure gauge kit to do it. CSV (cold start valve) could similarly be tested too. The pressure gauge kit costs about $60 from J.C. Whitney. Things that primarily interets me when I do CIS troubleshooting are: fuel pressures and vacuum. Tony |
take a look at the aux air regulator (AAR) on the right side of the motor. if it is stuck, it will make for a bad idle when cold. it should also have 12v on the connector.
the PO may have compensated for it by changing the idle when warm.
