Can electric windows be lowered/closed manually?
Need some help. Car is in parts and I need to lower the window a tad. Can I get them down manually? Tx
Champaign and Burgundy 3.2 (1986) Ex-C4 91 Ex C4 93 A8 3.0 TDI X5 |
easy to hook up a battery to the two wires from the motor. swap wires for the other direction.
Tx, I'll give that a try. I thought there was some kind of mechanism to do this similar to the sunroof.
According to my '88 Owners Manual the small door mounted speaker grill gives access to a hand crank location. I believe the hand crank tool is in the toolkit.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
Very helpful Andrew. Thanks.
Man,..I need to reread my 89 manual...that's good info! I hope to find it there, as you did.
If it's NOT there (in the manual), I'll look at my Bentley manual to see if the same applies to a "89. THANKS ANDREW!!! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Interesting. I don"t think my 87 has this option. I"ve never seen that tool.
1987 Carrera, Venetian Blue. |
I've always wondered what that thing in my toolkit was for. My '88 came with an '86 manual that doesn't talk about the emergency instructions.
Alan Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again Present: '00 Boxster S "Happiness is not around the next corner......happiness IS the next corner." |
Not in my toolkit either. Its a hex wrench but don't know the size...trying to get pass. side window down manually.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
FYI...managed to figure out that, in my case, the problem was the wire harness in the front wing just ahead of the passenger side door. I wiggled that around based on a suggestion on another thread and now the switch for the passenger window on the driver's side and the actual switch on the passenger door work. Not sure what I can do to really "fix" the problem but at least it's working, more or less.
