dshepp806's Avatar
'89 Cruise control cable break/Fix?
My 1989 cruise control cable has lost the barrel end connection (attached to the cable) at the actuator end for the throttle body...it just broke off.
Have ye' gents a quick fix ,..? Or must I just lay down the ~$200 for a new CC cable..?
I would imagine one could get a "barrel" of sorts (even the original?) ,..drill it,..then crimp,...BUT where would you get the necc. cable slack for the adjustment?
Enlighten me...
Thanks,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-26-2009, 03:43 PM
Zeke's Avatar
I don't know the exact answer, but couldn't you cut back the cable just a little and install an extension using a cable coupler ?
Old 05-26-2009, 03:56 PM
A few plastic tie wraps should do the trick.
Old 05-26-2009, 04:00 PM
E Sully's Avatar
If you're interested I have an 86 CC servo and cable I'm not using. $125.
Yeddy2@optonline.net
Old 05-26-2009, 04:19 PM
aj88cab's Avatar
'87-'89 Carreras used an electric CC servo...but, the cable might work.
You could try some of that epoxy putty stick stuff that you find in the plumbing section of your hardware store. It sticks to just about anything and sets up rock hard. Mold it around the barrel end connection, make it look pretty, and no one will know Just make sure everything is set, because that adjusting nut will never move again!
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 05-26-2009, 04:31 PM
dshepp806's Avatar
I don't quite see what I'm after in the photo. I already have tie wraps holding the plastic piece within the metal framework (feedthru),...My worries are at the barrel end break off at TIP of cable....did I miss something here?
Best,
Doyle
Middle Georgia
Old 05-26-2009, 04:43 PM
dshepp806's Avatar
Thanks for all the replies,..I've spent the frikin evening looking for that "barrel",..to no avail.
May have to check out Milt's cable coupler...
Thanks to all..
Best,
Doyle
Middle Georgia
Old 05-26-2009, 04:44 PM
dshepp806's Avatar
Very cool site, Milt,..everything you could possibly need.
Thanks!
Doyle
Middle Georgia
Old 05-26-2009, 04:45 PM
CBRacerX's Avatar
The inside cable here can be replaced with good old bicycle cable. Your local bike shop can attach a "barrel" connector to either or both ends for you.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 05-26-2009, 04:54 PM
Goth's Avatar
I pulled the cable out a bit. Cut about 1/4 inch off of the outer cover. Then put one of these on the end of the cable. I forgot where I got it at, perhaps in the lawn mower section of Sears.
EDIT: I think I bought it at Kragen auto parts.
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Last edited by Goth; 05-27-2009 at 06:58 AM.. Reason: I think I bought it at Kragen auto parts.
Old 05-26-2009, 05:15 PM
dshepp806's Avatar
Thanks, again, guys.
Best,
Doyle
Middle Georgia
Old 05-27-2009, 03:25 AM
