-   -   replacing O2 sensor 1987 gasket?? (http://forums.pelicanparts.com/porsche-911-technical-forum/476634-replacing-o2-sensor-1987-gasket.html)
captainlewis 05-26-2009 10:03 PM
I am replacing the o2 sensor is there an O -ring or a sealing washer that I should use, thanks JL
m110 05-26-2009 10:18 PM
No, just like a spark plug--integral seal. Some use copper based anti-sieze. But JUST a whiff on the threads.
wildcat077 05-27-2009 02:37 AM
I just replaced my original cat with a MK premuffler on my 89 Coupe and there was no gasket on the O2 sensor.Spray a bit of loose nut and with a 22mm wrench it came off easily,just be careful not to twist the wires too much,although you are replacing the unit anyways...
