Calif. SMOG test w a turbo 3.2?
I miss having a turbo'd Porsche and some times think of sticking a turbo on my 85 3.2 Carrera.
I am thinking I would have to take it off every 2 years and convert my car to near stock to pass. Would end up with low compression pistons at some point (8/1?). Any thoughts? Could I build it in a way to just add a cat and get it to pass? ;) |
Talk to the DMV/BAR Referree and they will tell you the requirements. If you take a later engine and transfer EVERYTHING and do a few mods to the sensors, you will pass.
I remember the "Old" days. I used to remove the needed components every year to do the smog test, finally I got "Smart" I got a different chip with the needed values and it passed every time and for the rest of the 11 months it was nothing BUT pleasure; we now don't have to worry about it anymore here in Florida :D
We have a visual in Ca.
I think all I have to do is have a Cat and pass the shif test but not sure. Ben, using a stock 930 w cat migh work, then could pull it off. It might be possible to find a station that dose not know the 911 and as long as it looks like a stock install and has a cat I might be ok. Not sure if a turbo and large aftermarket intercooler will triger the visual. I wonder if the Calif. EBA computer always says if it has a turbo or not? |
Removing the turbo every two years is the other option. |
| All times are GMT -8. The time now is 12:20 AM. |
