Noise with no idea
I took the Carrera out this evening and starting hearing this funny noise. I've heard it before but it's always gone away. Well this time it got bad and persisted. It's sounds like it's rotational. At first I thought maybe a wheel bearing or something to that effect. But it starts with acceleration, slowly then as speed increases the 'rotation' increases. But when I let off the accelerator it will stop. Also if I have the accelerator down and put in the clutch it stops. Any ideas?? Clutch going out? :(
Thanks in advance for any thoughts. |
I think we will need more that that.
pitch source loudness nature: grinding, or flapping, or scraping |
PITCH, not quite sure, certainly not a high pitch. SOURCE, kinda sounds like it's coming from the right rear of the car. LOUDNESS, Fairly loud when starting out then mellows to a constant drone NATURE, that's what I meant by rotational, certainly isn't a grinding noise nor flappling. maybe like clacking? Thanks |
clutch or throwout bearing?
Bumpity-bump
Is your gear oil full/fresh? |
Does it increase with increase in wheel movement or motor movement (i.e. does it change with speed of the motor or speed of the car)?
Probably nothing a new set of Altons and a 3.6 won't cure ;) |
I do think the wheels would fix it! 3.6? na but will go faster. |
CV Joints?
Never seen a clutch engagement quieten a CV issue....
Doyle |
What does it do when the car is in neutral, with and without the clutch engaged?
What happens to the noise each shift? I think you might have inferred that the noise went away on each clutch action, but I wanted to make sure.
If that's the case, I'm going to take a WAG and say check your trans and motor mounts. |
Take a run, get up to speed, put it in neutral and that will tell you CV, wheel bearing, rotor issue engine or tranny mounts.....then turn while in neutral, thats when the wheel bearing, CV and mounts are stressed the most. Once you discount that, check the fan belt (with cold engine) to see if its loose. After start-up feel the top of the fan housing to check on an alternator bearing vibration. If all these are okay...continue to Plan B because........this is the extent of my knowledge. Best of luck.
I will tell you this.................a few weeks ago I was experiencing a crazy metallic noise in my left rear. It turned out that a small welded flange that connects the heat exchanger to the exhaust port (where muffler attaches) broke and the vibration caused a high pitched metallic sound!! Fixed in an instance. Bob |
| All times are GMT -8. The time now is 10:24 AM. |
