Cattler's Avatar
Porsche Crest Help with Body Seal
My right rear fender to bumper seal sticks out in the center. I can push it back in but it always eventually pops back out in the center. I looked inside the fender and noticed that the metal edges are bent a bit away from each other. I tried to press them together with a pair of pliers--didn't make a bit of difference.
How can I get this seal to stay in?
Thanks,
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
Old 05-30-2009, 05:56 PM
Immature Member
dentist90's Avatar
I have the same problem with my front fender/cowl gasket. I'm gonna guess that the only long term repair is to unbolt the parts and sandwich in a new seal.
subscribed.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 05-30-2009, 07:26 PM
subscribed.
Essentially that's what I did a few years ago. Loosened the bolts, removed the old seal, slipped in the new seal and snugged down the bolts. It's been fine ever since. I go the seal from Pelican.
Jerry M
'78 SC
Old 05-30-2009, 07:35 PM
Ever jump a Porsche?....
78targa's Avatar
Well, One thing you could try is to remove the bumper extention and then try to gently straighten out the fender and extention lip. Most likely you won't be able to get the two pieces of sheet metal to sit flat against each other if you just try to squeeze them together. Separating them and then gently bending should get them to sit flat.
Make sure that you have all three mounting bolts in place for these pieces too!
Casey
Road-rally, Targa Newfoundland junkie!!!
1969 RSR 3.4L PCA class GT-3 (in progress)...1800 lbs and dropping
Thinking of driving in TARGA NEWFOUNDLAND? Contact me and I can help answer your questions. The event is awesome!
Old 05-30-2009, 09:31 PM
