-   -   72 window help (http://forums.pelicanparts.com/porsche-911-technical-forum/477224-72-window-help.html)
72 four door 05-30-2009 01:04 PM
72 window help
Am in the process of installing a driver side door/window frame and the glass separated from the track that it lays in. The old rubber is worn out. Does pelican sell that rubber ? Or should I use something else?
cfc 05-30-2009 04:50 PM
rubber
Why not call Pelican and ask?
72 four door 05-30-2009 06:30 PM
Cause I looked it up on pelican and couldn't find it and was hoping someone might know! And its sat and pelican is CLOSED. Can I get a response from people in the know, Thanks
dafischer 05-30-2009 07:26 PM
If you're talking about the channel that the bottom edge of the door glass sits in, there's a universal composite tape that lays in the channel, and the channel is then lightly tapped onto the glass. You don't need a Porsche part, check with an auto glass shop near you, they should be able to supply some.
Where in NJ are you?
724doorE 06-02-2009 03:30 PM
Yup try the tape had the same problem on the drivers side
