Old 60's Porsche Tech
what lbs pressure to you power bleed at???
Have an 1987 carrera have Jerry rigged a pressure bleeder with a pressure regulator, what is the max lbs pressure to bleed at, thanks JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Our power bleeder works the best between 10-15 PSI.
80 911 SC, Orem, Ut
The thing I read said 14lbs.
NOTE: When it says to crimp off the breather line to the fluid tank, do not skip this step. I did and it cost me a half a can of fluid on the ground. I use a pair of vice grips with a rag for protection and clamped the breather line off. Really a great way to bleed the brakes.
Rob 1980 911 SC |
