Wheel size questions
I have a 1986 911 carrera non turbo with stock flares.... I'm wondering what max size tires I can go without having to weld on some steel flares, I have 205's on the front and 225's on the back right now and it looks like theres maybe between an inch to an inch and a half of space on the rears before i touch the fenders......any ideas on how big I can gow without adding on flares?
255/17 is a popular size for the rear of SC/Carreras with standard flares.
265/45 will fit but that size is pretty slim in a street tire. If you have stock 16 inch wheels the biggest issue is finding tires in a "fat" size that will work. The tire diameter for our cars is right around 25" here's mine with 245/45/16 with Sumitomo tires.I also have a .25 spacer installed.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
If you'll do a search on "tire size" "largest tires", or similar term, you'll find more than you ever wanted to know.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Administrator
245/275
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Here's a good one:
Maxing out wheel/tire combo on Carrera flared car Ed, don't you have a fairly wide tire on Ruby?
Northern Motorhead
I just installed a set of 9 inch wheels with 245/45/16 tires on the rear and 225/50/16 tires on 7 inch wheels this weekend on my 89 Coupe with no issues... I will be lowering the car to "euro" specs as soon as i replace all four original shocks with new Bilsteins.
Right now i'm running a two finger gap between the top of the tires and the fender lip front and rear as that is the lowest i could go for now without any rubbing... Had to go for a few test drives and readjust the front height as anything lower than that would rub on the tires over bumps ! There is no concern whatsoever with the rear,the front is a little touchy with "tired" 20 year old shocks... |
I suggested the search button, as there are alway's some asterisks and "buts" with this question on max sizing.
zugelassener benutzer
7&9x16s BFG GForce SS 205/55 & 245/50s
![]() 16", not lowered, yet
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing 7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo 32C #7 |
Northern Motorhead
245/45/16 on 9 inch and 225/50/16 on 7 inch,installed on Friday with a 2 finger gap on all four fenders,will be lowered as soon as i replace original shocks with Billsteins...
Check out the new Kumho XS tires. The have a 265/45/16 that will work on a 9" rim. Is it suposed to be at the top of the heap on the near R type tires.
One of the best proven set ups seems to be 205/245's. As Jack says, 275 17's is the widest rear and is what a lot of the PCA stock class guys are running. It should require rolling the fenders and might require moving the oil lines. Not an expert in this. |
Northern Motorhead
Rear view 89 Coupe
Looks damn good haha, so should I move the current rear 225's up front and buy 245's for the back?
Northern Motorhead
It worked for me...
The problem is to find a tire company that makes the matching sizes for the front and back ! I found that TOYO with their Proxes T1R makes a wide variety of sizes and i'm glad i chose them because they are a lot smoother and quieter over road irregularities than the Michelin Pilots i had on previously. I've still got the the 20 year old original shocks on the car... i just recently purchased it and will be replacing all four next weekend... but i have a two finger gap all around between the tires and fender and nothing rubs ! Will lower it slightly more after shock replacement ! |
| Tags |
| 911 , porsche , rims , tires , wheels |
