jaybird840's Avatar
Send a message via Skype™ to jaybird840
Which crank pulley?
Which size crank pulley do I want for my 2.7RS spec rebuild... a 116 or 127? I have updated the fan to an 11 blade model. I want to get rid of the double pulley, and make sure that it is correctly sized. Photo below....
Jaybird
'75 914--slowly becoming a supercar
2.7RS spec rebuild in progress
Old 05-21-2009, 11:04 PM
jaybird840's Avatar
anyone?
Jaybird
Old 05-22-2009, 01:40 PM
356RS's Avatar
The 116mm is what was used on all of the early engines up to 77 as far as I know.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-22-2009, 01:53 PM
jaybird840's Avatar
Here's my second question
Now I'm really stumped. My fan pulley appears to be solid... With a solid fan pulley and a solid crank pulley, how do you adjust the tension? I'm familiar with the two piece pulleys that you add or remove shims to, but not the solid one. What gives?
Jaybird
Old 06-02-2009, 06:36 AM
Addicted to Racing
edbaus's Avatar
No idea. Never seen that. I have seen a LOT of fans. The only time I have seen the solid fan pulley is with a serpentine conversion with a tensioner.
I would just convert to the regular two piece.
Ed
Check out the parts for sale:
http://www.demonspeedmotorsports.com
PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer.
See my list of current cars in my garage.
Old 06-02-2009, 06:44 AM
Fast Corners's Avatar
That extra pulley on the fan is to drive the stock air pump. If you have an aux oil cooler then I would think the 116mm crank pulley will work fine.
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 06-02-2009, 09:39 AM
jaybird840's Avatar
DOH!!! I get it now... I've never seen this motor fully assembled. The fan belt rides in the "v" formed by the front of the fan and the back of the solid pulley. Now if I can just locate a single crank pulley, and single fan pulley, I can ditch a complete set of pulleys!!! thanks, Fast Corners!
Jaybird
Old 06-02-2009, 01:14 PM
