Wiring in doors question
I have gutted my doors in my '86 Carrera in its transformation to a race car: no windows or electronics (although I kept the door handle and latch). I either disconnected or cut all of the wires to all of the motors, etc. inside the doors. I would like to pull the wires out.
I can see where a number of wires come from the front trunk near the passenger door then disappear into about a 2" wide hole and go into the area where the door is hinged to the body. Without removing the door (which I would prefer not to do) I can't see where the wires run between when the leave the trunk and before they go into the door. My question is this: Are there any wires running through that area that go to anything other then door components? Basically, I want to know if I just start yanking wires from the trunk side, are there wires I don't want to be pulling out because they go to something other than door parts?
1964 356 C 1970 911T 1974 914 2.0 1986 Carrera Spec911 race car #76 1990 Carrera 2 |
in and out of the door you have 2/4 speaker wires 1 ground 1 power door lock 1 pass door lock, power and ground to the window and maybe a line for heated mirrors if so equipped. that should be it most of those run down to the fuse panel but th speaker wires run in and up to the dash. hope this helps. you should watch cutting them if fuses are still in tact as you will short it out.
Thanks. I am not worried about anything like speaker wires (given that I have no speakers) or anything running to the door (since the doors are now just empty shells).
Are there any important wires that run out of that small hole near the back of the trunk beneath the passenger side A pillar that I am going to regret pulling out if I just start yanking?
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
electric mirror angle power etc wires
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
