-   -   Left Front Signal Fix (http://forums.pelicanparts.com/porsche-911-technical-forum/477720-left-front-signal-fix.html)
Paulporsche 06-02-2009 07:21 AM
I didn't see this in the first 100 search items so I thought I'd post it just to get the data in.
My left front signal light stopped flashing. All others worked and so did the emergency flashers.
I swapped in a new bulb and checked the fuse and relay. All seemed fine but the fault remained.
Remembering that the flashers are wired w/ the headlights, I opened up the H4 trim ring and found that one wire was down to 2 strands @ the spade connector. When I touched the wire it broke.
I renewed the wire @ the connector, replaced everything, and the flashers now work perfectly.
Simple fix; simple thread.
