-   -   Need help with hose identity (http://forums.pelicanparts.com/porsche-911-technical-forum/477768-need-help-hose-identity.html)
mytoy 06-02-2009 11:32 AM
Guys can anyone help identify where these hoses should hook up too? This first one comes from the firewall under the cruise control unit. It is broken off and I can not see a fitting where this could attach to on the left side of the engine. Now it might go over to the right side but I can't seem to find a missing hose connection there either.
http://forums.pelicanparts.com/uploa...1243967149.jpg
This second one comes from the transmission tunnel area. It runs along side the emergency brake cable, the throttle cable and the heater cables. It too is broken off and I have no clue where it would run to.
http://forums.pelicanparts.com/uploa...1243967440.jpg
Thanks in advance for any help you can provide. This is for an 83 911sc cabriolet.
Gogar 06-02-2009 11:45 AM
1st one looks to me like part of your evap/carbon canister setup. Second one, I don't know.
gtc 06-02-2009 11:55 AM
Edit: Nevermind... wrong size for the brake booster.
I admit, I just clicked this thread because of the title... :D
mytoy 06-02-2009 05:06 PM
Thanks Gogar. I think that you are correct. I believe that this hose goes on the left side of the air box as I found a nipple on there that the hose would fit and it was plugged off in a non factory manner. I hope that this is right. Will await further experts advise.
Now only need to figure out what that hose is in the second picture and where it hooks up to.
mytoy 06-03-2009 10:37 PM
Never mind guys. Found where the lines go to. Thanks for the replies.
