door keeps opening.
Hi guys. My 911 drivers door keeps popping out open on the road even when i lock it. It's bugging the crap out of me and was wondering how I can fix it. Everytime I drive it it pops out in the middle of the road. Has anyone had this problem and how do I fix it? Thanks.
Old 11-07-2008, 09:25 AM
you have not mentioned what year it is. But it sounds like the door latch is broken anyway.
You can do a quick test of the latch by leaving the door open, twisting the latch to the lock position and with a set of pliers wiggle it up/down and see if it releases. If it does move while trying to wiggle then it is broken ! If it releases its broken
you can post on the parts area a wanted ad and i am sure many here have what you may need
caveat: we have seen severe rusted chassis cases where the car twists going over bumps or in turns and the door pops open- even with a good latch!
Hopefully that is not the case with your car
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 11-07-2008, 09:41 AM
Thanks! will give it a try tonight.
Old 11-07-2008, 10:38 AM
old man neri's Avatar
When was the last time you hard your door card off to lube all the internals? Maybe something is sticking, could be as simple as that.....hopefully. I know I had a similar problem with water getting in and freezing. The door would just not latch close at all. It would just release, something was frozen open. Lube and a hair dryer took care of it all.
Old 11-07-2008, 06:23 PM
Having trouble w/this myself. Took the door panel off and found second latch tooth was rounded, so I hit it with a dremal to sharpen the point of latch. This worked great for month or so.
Later, when I shut the door it wouldn't latch everytime, and would bounce open. So, I sprayed some teflon spray all over the latch. Now I get the same popping open again when I hit bumps.
It's a 73 Targa, so body twist is a thought but I replaced rockers and dogleg 2 years ago, and don't see any other signs that things are moving?
My next try will be to replace the spring that holds the latch latched.
Suprised I can't find more threads about this.
73 911T wide hipped RS look alike.
78 928 w/GT spoiler
Old 06-04-2009, 06:51 AM
