Remember
The Turk's Avatar
Electronic Speedometer Wiring
As part of a G50 conversion into my 75 I need to wire for an electronic speedometer.
I’m by no means a wiring wizard so I need to verify what I think needs to be done.
The back of the speedo has four connections, here’s how I planned to hook it up, if you have wiring experience please let me know if this is correct.
Thanks.
+ connects to switched 12 volts
- connects to ground
31b and A connect to the two sensor wires
Gary
1975 911S G50 3.5 Twin Turbo
Old 02-24-2007, 10:53 AM
Early_S_Man's Avatar
Porsche Crest
What year car is that speedo from, an SC?
One of the sender wires goes to [-] ground, the other to 31b, and polarity doesn't matter-- either wire at either location.
Terminal 'A' isn't used, as it is an accessory output terminal that goes to cruise control or Oxy Sensor Mileage relay -- if you had one!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-24-2007, 12:16 PM
Remember
The Turk's Avatar
I’m not sure what’s it’s out of, here’s a picture.
So I’ll hook up the + to switched 12 volts and the - and 31b to the sensor.
Thanks for the help.
Gary
Old 02-24-2007, 01:14 PM
Bird. It's the word...
Fishcop's Avatar
Pelican Archives: Thank you once again Warren Hall
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 06-05-2009, 07:31 PM
