advtracing's Avatar
Replacment panels questions-help wayne!!
I need some guidance here guys , i need to get the correct panels for a repair on a 72 coupe and with all the superseded numbers in the pet catalog i'm lost as to what is correct and not .
Number 1 - front scuttle panel
This does not appear on the stoddard / auto atlanta site for coupe but does for targa, but the targa number has changed to another item SS 91150308742GRV but i'm not sure if this will fit a coupe . My supplier has advised the new number 911 503 087 42GRV which is a supersession for 901 503 057 or do i need the whole part g90150309021 which is listed on stoddards?
panel no 2 is the rear cross member which used to be g91150183000 and
g90150108720 now i'm told it's Rear cross member 911 507 080 01GRV & 911 507 095 00GRV but the pet diagram looks like the outer part is the later addition for the rear reflector and not needed for the pre 73 cars ?
HELP!!!! very confused
"Funding my obsession one nut at a time"
Old 06-05-2009, 08:10 PM
Warren Hall Student
Bobboloo's Avatar
Both of those panels will fit but on the later rear cross member piece you'll need to remove the extra piece for the reflector to mount on. Just cut the spot welds. It'll also look a little different but will work fine. I have one on my 73'.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 06-06-2009, 10:40 AM
Warren Hall Student
Bobboloo's Avatar
Here's some pictures of the later rear cross member welded into an early chassis.
Here you can see where I drilled out spot welds for the rear reflector panel to remove it.
You can also see on the left how the later piece is slightly different in that the corners are angled rather than rounded.
Bobby
Old 06-06-2009, 01:06 PM
advtracing's Avatar
Thanks , we'll give it a go
Old 06-06-2009, 01:31 PM
