jh225's Avatar
Is the Starter Solenoid Wiring.........
Is the starter solenoid wiring the same on a '77 3.0 930 the same as a '84+ 3.2? Reason being is I only have the Bentley for the newer car but need to work on the '77.
Also, can the starter be removed on a 3.0 with 930 tranny without lowering the engine? I can't even see the top bolt.
1985 Carrera Targa in the fastest color......Black........Growing list of goodies now includes SW Chip, M&K premuffler, Sport muffler, DME update, etc.
Old 06-06-2009, 05:27 PM
Starter wiring and removal........
JH,
911 ('74-'77) use 3-terminal (15/30/50) type starters, while '78-'83 and early Carreras use 2-terminal (30/50) type starters. There are some similarity by not the same. So you have to check whether your car has 2 or 3 terminal starter configuration. Or your car might have undergone a conversion to later model starter.
The second part, you can remove the starter from your 915 transmission without any engine partial drop. You need a long 10-mm allen wrench to the remove the top Allen barrel type nut. Disconnect the battery connection before you try to remove the starter. Good luck.
Tony
Old 06-06-2009, 06:08 PM
jh225's Avatar
Originally Posted by boyt911sc View Post
JH,
Tony
This is not a 915 trans, it is a 930 (4 speed)
The starter has 2 large lugs on the solenoid, and as of yet I don't know about a small terminal as I can't see the top of it.
Old 06-06-2009, 07:18 PM
