Front Brake Line Routing
Does anyone have some pictures showing the routing of the front brake lines on a 77 911 w/brake booster? I need to know from the tunnel up to the MC. Also the opening for a MC which attaches to the pedal cluster is there what covers this up?
Please send pic's to jdye@etcmail.com. Thanks In Advance |
Jim,
I am replacing the brake lines (along with everything else) on my 77. Take a look at this link tracking my progress. Let me know if there are pictures you need which are not include in the thread. http://forums.pelicanparts.com/porsche-911-technical-forum/328178-should-i-replace-theses-brake-fuel-lines.html Frank |
Still needing a photo showing brake lines form booster master cyclinder to connections at tunnel.
What I have done is sectioned a 1977 front clip onto my 1975 911s body. The 75 had a master cyclinder mounted behind the pedal cluster,now I have a vacume assited master cyclinder assembly in the front trunk. What I need is a photo showing how the brake lines are routed from the booster assited master to the front of the tunnel.PET shows the lines but there is no reference as to there location as they pass from the trunk thru the floor board area to the connections where they run to the front brake lines and feed the rear brake lines.
Jim,
My apologies for not posting this sooner. Here are a couple of pics I took showing the two F/R lines leaving the MC and then routing into the smugglers box area, and then another showing them routing down towards the front of the tunnel (note: steering rack is removed). The other pictures I posted in my thread should cover the view from the bottom, but let me know if you need more - either closer or from a different angle. Frank http://forums.pelicanparts.com/uploa...1247346349.jpg http://forums.pelicanparts.com/uploa...1247346408.jpg |
| All times are GMT -8. The time now is 10:25 PM. |
