 cv joint hi,just re packing bearings and replaceing boots on my 72,put the thrust washer on  and clip wont go in groove reverse washer and fits easy,is there a tool to put tension on the bearing assembly,any help and advice would be greatly appreciated.thanks,frank:confused: |
 The spring washer mustbe placed in the correct direction and a press used to compress it enough to install the clip. regards, Phil |
 cv joint thanks phil, so will have to figure something out,seeing as it is a one time only deal,best wishes,frank:) |
| All times are GMT -8. The time now is 06:05 PM. |
