Ski it like a man
How do I tighten a loose door handle?
Exterior passenger side door handle is loose, and pulling away from the car on the end where the lock is. I would assume I will need to take off the door panel and have a look. Then what?
Thanks. -KVH
'83 SC Targa |
I would rather be driving
Roll the window all the way up and remove the door panel/armrest, etc. There will be two 8mm nuts that hold the door handle in place.
The forward one holds the leading edge of the handle. It is accessable by reaching inside the door. The rearward one is just in front of the locking mechanism. it is accessable by an access hole in the interior door sheet metal. Use 1/4" sockets. An extension is your friend.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Ski it like a man
Thank you
'83 SC Targa |
