Oliver Klosov's Avatar
Sunroof switch
Will somebody please explain the procedure to replace the electric sunroof switch for a '79 911 SC? Do I have to disassemble part of the dash? Is there a simpler approach?
'79 911SC Coupe
We may be lost, but at least we're making good time...
Old 06-10-2009, 04:47 PM
Designer King
Paulporsche's Avatar
You should be able to push it out from behind, as w/ the gauges.
BTW I was able to repair mine. It was easy to open up. The rocker inside rides on a pivot and makes contact w/ some metal pieces. I think all I had to do was clean it and rebend the contacts, which had fatigued over time and use.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-10-2009, 06:33 PM
