Designer King
Paulporsche's Avatar
Does this valve cover look right to you?
This is a shot of the driver's side lower valve cover. Note the opening toward the end nearer the front of the car. Am I seeing an unused plug from my twin plug setup? Is this OK to be exposed? Should there be some sort of cover over this?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-09-2009, 03:05 PM
Goldfinger
Mattcamp's Avatar
Sure looks like a spark plug to me. How many plug wires do you have on the top-side of your motor?
1984-Carrera (pewter metallic)
Old 06-09-2009, 03:08 PM
I've got a plug (and plug wire) there on my twin plug setup.
Old 06-09-2009, 03:59 PM
Designer King
I'm just using 6 plugs now because I just have 1 x 6 plug diz. So I'm pretty sure that's one of the unused 6 plugs.
The thing is--is it OK that I have that opening there?
Paul
Old 06-09-2009, 07:32 PM
To be safe, I would bend the sheet metal back into place to keep large debris and quantities of oil or grease out of there.
Old 06-09-2009, 07:49 PM
AutoBahned
RWebb's Avatar
why not stick a rubber plug end on those 6 plugs?
just seal it up
Old 06-09-2009, 08:09 PM
Rouxzy's Avatar
What RWebb said. I would think that would be the best thing to do.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 06-09-2009, 08:48 PM
