Do yourself a favor, DME
On my way back from picking up my daughter from gymnastics in my 1987 Carrera with 54,000 mi. my baby died! Couldn't understand it. Cruising along at 55 mph it was like someone just reached over and turned the ignition off. Luckily I was only 2 miles from home and my buddy came to my rescue with a tow rope and his truck. So I logged in to Pelican parts and began my search. It seemed that all the threads I could find pointed to the DME relay under the drivers seat and they were right! On new relay later and I am back in business.
So, thank you my fellow Pelicans and quick shipping from Wayne!
Old 06-08-2009, 05:45 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Moral of this story, the $35(?) new DME relay should always be in your glovebox...
Gary R.
Old 06-08-2009, 05:59 PM
You mean that DME relay only lasted 22 years??
What happened to Porsche quality??
Doug
Was 2.7racer.
'76, 2.7 w/Webers, JE pistons, Solex cams. Elephant bushings front & rear, 23mm & 28mm torsion bars, big brakes front & rear, Pertronix. Track car.
'85 3.2 stock, Orient red, comfy street car.
Old 06-08-2009, 07:49 PM
Warren Hall Student
Bobboloo's Avatar
Dang! Your garage floor looks nicer than the the floor in my house!
P.S. The car doesn't look half bad either.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 06-08-2009, 10:33 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Very comon VW and Porsche bug. Unfortunately, there was a batch of relays made in Hungary that went much faster - some lasted less than a year. My guess is that the switch to Pb-free solder was the root cause. So you should always carry a spare. Cheap insurance.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 06-08-2009, 10:41 PM
MBruns for President
JeremyD's Avatar
I carry two!
Old 06-09-2009, 05:09 AM
The Chef
Guest
Posts: n/a
I carry one as well as a spare fuel pump relay, furl pump, belt, fuel injector seals. That's just me but I would rather have it if it needs replacing hours from home.
Old 06-09-2009, 11:53 AM
Monkey Butt Forespin
84_Carrera's Avatar
I have one in the glovebox, and one in the toolbox in the garage.
I also keep a spare black & a red relay also.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 06-09-2009, 01:41 PM
dshepp806's Avatar
Originally Posted by JeremyD View Post
I carry two!
+1 on the +2 !!!!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-09-2009, 01:58 PM
gtc gtc is offline
abides.
gtc's Avatar
I carry nine spare DME relays on my person at all times, especially when showering.
Graham
1984 Carrera Targa
Old 06-09-2009, 04:46 PM
Transplanted User
mkossler's Avatar
Great to hear everything worked out well!
I wear my DME relays woven together as a jacket. There are 238 of them.
And since I drive an SC, I never have to use them up! =oD j/k...
Matty K. - 82 SC Targa - SCWDP member #0052
"Racing - the sport that requires more than one ball to participate"
Old 06-09-2009, 05:42 PM
