high beam flasher
Has anyone replaced their high beam stalk on a 1987 or the like 911? Mine works when you push the stalk to leave the highs on but when you pull it towards you when the lights are off (you know when you want to flash a fellow driver) no dice! If so how difficult to do?
Old 06-11-2009, 04:45 PM
scottb's Avatar
Dozens of posts on this subject. Do a search for stalk switch. It's an easy job, but there are a bunch of wires between the stalk switch and the headlight switch. Remove/replace them one-by-one.
Also, consider installing a relay kit in the headlight system. It'll save your new switch from frying. I'm pretty sure out host sells them.
Scott
1984 Targa
Old 06-11-2009, 04:48 PM
Paul K's Avatar
+1 for the relay install. Very quick & easy, plus it made my FTP work again without my having to install a new switch.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 06-11-2009, 04:50 PM
