-   -   930 -> Carrera 3.2 SwayBar Interchange (http://forums.pelicanparts.com/porsche-911-technical-forum/479255-930-carrera-3-2-swaybar-interchange.html)
vreference 06-10-2009 09:55 AM
I was searching for an answer to this but there is only one year of the G50 930 so I didn't have much luck.
A pelican is selling a set of '89 930 bars. I have an '89 Carrera 3.2 that needs a rear bar and all hardware. I don't even think my car has anything sway bar related attached to the trailing arms at this point. I'm sure I'll have to buy some hardware but I suppose my question is:
Is the '89 930 Rear sway bar interchangeable with the '89 Carrera 3.2?
trak ratt 06-10-2009 10:32 AM
Maybe. The front should be a simple swap. Don't have any documentation with me but your '89 has the largest front bar offered in the earlier series. I think that includes turbos. Rear may. G50s take a diff bar from 915 but then Turbos have the big 4 speed so it's bar may fit over the G50 too.
vreference 06-10-2009 11:10 AM
I believe '89 was the only year of the 930 to get a 5-Speed. I want to say it was a g50; but I imagine the trailing arms didn't change much on the 930s; so I expect if anyone has fitted a 930 bar to a 911 or vice versa they will work?
